Header may not contain more than a single header
Hi Guys,
I have swapped over to Databridge and on the whole the experience has been ok all but for a few issues.
Background to issue:
Security assist pages have been created.
Ran data assist from Databridge to create insert / update / detail pages .
During wizard I chose file for 8 inputs.
After creation I changed the record set Variable run time value to the $_SESSION["SecurityAssist_TraineeID"]
so when a user logs in, it logs into their account. This works fine.
the problem I'm getting is when you use the file filed to upload an image, on submit I get the following error
Warning: Header may not contain more than a single header, new line detected. in C:\xampp\htdocs\xxx\xxx\cwi_update.php on line 258
I would appreciate any help with this.
I have attached a text file of my page code which is generated as is all but for adding security and Variable run time value.
Kind regards
Jonathon
