Ok so this is what i found, not sure if at random or triggered.......but i have two, yes 2 different management screens......one is just the (/admin/) screen and one id the (/admin_cms/). so i ran a find report and count these below, should i rename or delete and or is there a setting that can compensate for this. Because of this i get an error that the database is not connected......
report:
<?xml version="1.0" standalone="yes" ?>
<mm_report>
<mm_reportname> ResultsReport cms 06.12.xml</mm_reportname>
<mm_reportdate>06/27/12 14:44:46</mm_reportdate>
<mm_reportlocation>C:\\Users\joe-3\Documents\My Web Sites\change the way i look\</mm_reportlocation>
<mm_reportitem>
<mm_file>admin_cms\pages.php</mm_file>
<mm_displaystr><![CDATA[ $abs_prefix = str_ireplace('/admin_cms', '/', str_ireplace('\\', '/', dirname(realpath(__FILE__)))); ]]></mm_displaystr>
<mm_data mm_rangemin="1987" mm_rangemax="1996" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\admin_cms\pages.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>admin_cms\common\listfolder.php</mm_file>
<mm_displaystr><![CDATA[ $root_folder = str_replace('/admin_cms/common/listfolder.php', "", str_replace('\\', "/", realpath(__FILE__))); ]]></mm_displaystr>
<mm_data mm_rangemin="861" mm_rangemax="870" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\admin_cms\common\listfolder.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>cms\index.php</mm_file>
<mm_displaystr><![CDATA[<?php header('Location: ../admin_cms/users_login.php'); ?>]]></mm_displaystr>
<mm_data mm_rangemin="27" mm_rangemax="36" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\cms\index.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>CSSMenuWriter\cssmw\menu.php</mm_file>
<mm_displaystr><![CDATA[ <li><span><a href="../../admin_cms/index.php"><img src="../../images/menu-home.png" align="absmiddle" />Home</a></span></li> ]]></mm_displaystr>
<mm_data mm_rangemin="285" mm_rangemax="294" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\menu.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <li><span><a href="../../admin_cms/activity.php"><img src="../../images/menu-activity.png" align="absmiddle" />Activity</a></span></li> ]]></mm_displaystr>
<mm_data mm_rangemin="413" mm_rangemax="422" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\menu.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <li><span><a href="../../admin_cms/settings.php"><img src="../../images/menu-settings.png" align="absmiddle" />Settings</a></span></li> ]]></mm_displaystr>
<mm_data mm_rangemin="632" mm_rangemax="641" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\menu.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <li><span><a href="../../admin_cms/help.php"><img src="../../images/menu-help.png" align="absmiddle" />Help</a></span></li> ]]></mm_displaystr>
<mm_data mm_rangemin="804" mm_rangemax="813" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\menu.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>CSSMenuWriter\cssmw\treexml.xml</mm_file>
<mm_displaystr><![CDATA[ <mm:treenode value="Home|/admin_cms/index.php" level="1"></mm:treenode><mm:treenode...]]></mm_displaystr>
<mm_data mm_rangemin="372" mm_rangemax="381" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\treexml.xml" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[...value="Activity|/admin_cms/activity.php" state="expanded" level="1"> ]]></mm_displaystr>
<mm_data mm_rangemin="447" mm_rangemax="456" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\treexml.xml" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <mm:treenode value="Settings|/admin_cms/settings.php" level="1"...]]></mm_displaystr>
<mm_data mm_rangemin="575" mm_rangemax="584" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\treexml.xml" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[...value="Help|/admin_cms/help.php" state="collapsed"...]]></mm_displaystr>
<mm_data mm_rangemin="669" mm_rangemax="678" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\CSSMenuWriter\cssmw\treexml.xml" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>install_cms\complete.php</mm_file>
<mm_displaystr><![CDATA[ header('Location: ../admin_cms/index.php'); ]]></mm_displaystr>
<mm_data mm_rangemin="1144" mm_rangemax="1153" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\install_cms\complete.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>install_cms\database.php</mm_file>
<mm_displaystr><![CDATA[ 'abs_admin_image_root' => $abs_root . 'Images/admin_cms/', ]]></mm_displaystr>
<mm_data mm_rangemin="4151" mm_rangemax="4160" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\install_cms\database.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>install_cms\global.php</mm_file>
<mm_data mm_rangemin="144" mm_rangemax="153" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\install_cms\global.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>Templates\admin.dwt.php</mm_file>
<mm_displaystr><![CDATA[ <a href="../admin_cms/index.php"><img src="../images/logo.png" width="154" height="79" alt="PowerCMS" /></a> ]]></mm_displaystr>
<mm_data mm_rangemin="2058" mm_rangemax="2067" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\Templates\admin.dwt.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <a href="../admin_cms/manage_users.php">Manage Users</a> | ]]></mm_displaystr>
<mm_data mm_rangemin="2298" mm_rangemax="2307" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\Templates\admin.dwt.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <a href="../admin_cms/contents_search.php">Advanced Search</a> | <a href="../admin_cms/users_login.php?logout=1">Log Out</a></div> ]]></mm_displaystr>
<mm_data mm_rangemin="2398" mm_rangemax="2407" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\Templates\admin.dwt.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_data mm_rangemin="2463" mm_rangemax="2472" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\Templates\admin.dwt.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ <form action="../admin_cms/contents_results.php" method="get" id="WADASearchForm"> ]]></mm_displaystr>
<mm_data mm_rangemin="2606" mm_rangemax="2615" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\Templates\admin.dwt.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_file>WA_CMS\WA_CMS.php</mm_file>
<mm_displaystr><![CDATA[ $rootDir = rel2abs("../admin_cms/contents_update.php",dirname(__FILE__)); ]]></mm_displaystr>
<mm_data mm_rangemin="1739" mm_rangemax="1748" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\WA_CMS\WA_CMS.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ $globalUpdate = abs2rel(rel2abs('../admin_cms/contents_update.php',dirname(__FILE__)),$GLOBALS['start_Dir']); ]]></mm_displaystr>
<mm_data mm_rangemin="4066" mm_rangemax="4075" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\WA_CMS\WA_CMS.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
<mm_reportitem>
<mm_displaystr><![CDATA[ $globalUpdate = abs2rel(rel2abs('../admin_cms/optimization.php',dirname(__FILE__)),$GLOBALS['start_Dir']); ]]></mm_displaystr>
<mm_data mm_rangemin="4248" mm_rangemax="4257" mm_filename="C:\Users\joe-3\Documents\My Web Sites\change the way i look\WA_CMS\WA_CMS.php" mm_replaced="false" mm_matchedtextdirty="false" />
</mm_reportitem>
</mm_report>
