comments field & font size
Thread began 6/22/2012 3:11 pm by barkmail | Last modified 7/09/2012 1:05 pm by Jason Byrnes | 1096 views | 13 replies |
barkmail
1. Added a text area form into the checkout.php page so my customers can write out any special instructions.
- How do I get this information to pass onto the confirm.php page
-and then pass to Paypal so that I can receive that information in my Paypal payment notification?
2. How can I increase the size of the font within the text fields for the customer to input their info within the checkout.php page?
I have increased the sizing of the field fonts, but can't figure the input font sizing - they are VERY small.
thank you
what paypal system are you using? PayPal Payments Pro or standard?
See the "Styling Forms with CSS" article on the Road Maps page:
roadmaps/
barkmail
Paypal Standard.
Changed the font characteristics - thank you for pointing me to those instructions.
on the confirm page, there is a collection of hidden elements that passes the cart information to paypal, add 2 new hidden elements:
the first will set the name of the option being passed as Special Instructions:
<input type="hidden" name="on0" id="on0" value="Special Instructions" />
the second is to capture the value form the checkout page:
<input type="hidden" name="os0" id="os0" value="<?php echo((isset($_POST["instructions"]))?$_POST["instructions"]:""?>" />
this example assumes the text area is named "instructions"
barkmail
thank you
How do I get the information from the checkout page to the confirm page?
that what the value of the hidden element is for. assuming the name of the tex field is "instructions" this code will capture the value from the checkout page:
barkmail
I am trying to put the comments/special instructions form on the confirm page rather than the checkout page since this seems like it would be easier for all. So for now...table my last question as to how to transfer the info from the checkout to the confirm page.
I have put this field at the end of the confirm page. Does this impact where I place the code lines to transfer this info to Paypal?
for some odd reason the
modify information button
& submit button
have both become very large....
how can I get them back to normal?
barkmail
OK.
Took the text area for special instructions off the confirm page and am keeping it on the checkout page.
It seems I've goofed up my button assets because they are all stretched.... help.
barkmail
OK again...ignore my last couple of posted replies.
I deleted the confirm and checkout pages and rebuilt them. All is fine now.
Now back to communicating the new "special instructions" field within my checkout page to Paypal...
I put the code into the program right after the existing two codes to transfer style and engraving information (which both of those work).
Did a test and did not see anything pass to Paypal (nor onto the confirmation page - which I'm not sure I would see it there or not?).
Am I putting the code in correctly - wrong area - wrong something?
Instead of naming it os0, should I name it os2 (since I already have an os0 and os1)?
thanks.
If you already have os0 and os1, the yes, they should be named on2 and os2.
the new form elements should be inside the form tags.
send a link where i can see the problem to get a better idea of the cause.
