HELP!What have set up wrong to get this error!<
Thread began 6/22/2012 1:47 am by russell298997 | Last modified 6/22/2012 8:07 am by Jason Byrnes | 796 views | 1 replies |
russell298997
Running DW CS5.5 and loaded a site - set up local site as
C:\inetpub\wwwroot\EFTC\htdocs
and testing server as
htdocs/
I have two major problems.
Firstly, i have just tried to run universalmail and select some dynamic bindings - i get this DW message about Set Up instructions, telling me i have to create a site for this file, choose a document type, name a testing server and add a recordset - all of which i have done. i have numerous recordsets running on this page. any ideas why i am getting this type of error (see screengrab)
Secondly i cant get any page to show in live view - i get
HTTP Error 500.19 - Internal Server Error
The requested page cannot be accessed because the related configuration data for the page is invalid.
d Error Information
Module IIS Web Core
Notification BeginRequest
Handler Not yet determined
Error Code 0x80070005
Config Error Cannot read configuration file due to insufficient permissions
Config File \\?\C:\inetpub\wwwroot\EFTC\web.confi
i simply cannot see what file/folder requires more permissions - i seems to have given everything i can find full read/write permissions - anybody have idea where i might try...!?
the first error points to an issue with the Site Definition, specifically the Testing Server Settings in the site definition.
What happens if you try to open the bindings panel?
In the Site Settings, for the testing server, what settings are you using?
The second error is a problem in the IIS server configuration.
see the following page for troubleshooting details:
troubleshooting-http-500-19-errors-in-iis-7.aspx
