PHP Explode Search Results
Thread begun 6/21/2012 1:23 pm by Daryl | Last modified 6/21/2012 2:07 pm by Jason Byrnes | 5380 views | 3 replies |
DarylBeta Tester
I have a Data Assist database search which works OK, but I am trying to figure out how to explode the result so that only the first sentence that contains the keyword is shown by looking for the deliminator of a fullstop and a space.
Has anyone else done this?
Ian S
Yes... In the Data Assist Search GUI there is a value type of keyword.
I use it frequently for checkbox arrays.
Choose that and it should work OK
Cheers
Ian
DarylBeta Tester
Hi Ian
I am using Keyword as the type, but this shows the entire database record that contains that keyword.
I just want an extract of the record that contains that word
here is an example outside of Data Assist Search that should help give a direction for accomplishing this:
$heystack
"The quick brown fox jumps over the lazzy dog. Humpty Dumpty sat on a wall. Jack and jill went up the hill";
$retStr $heystack;
$heystackArray explode(". "$heystack);
if(isset(
$_POST['keyword']) && $_POST['keyword'] != "") {
$needle $_POST['keyword'];
    for(
$i 0$i sizeof($heystackArray); $i++) {
$termArray explode(" "$heystackArray[$i]);
        if(
in_array($needle$termArray)) $retStr $heystackArray[$i];
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document</title>
</head>
<body>
<form id="form1" name="form1" method="post"  action="">
  <input type="text" name="keyword" id="keyword" />
  <input type="submit" name="button" id="button" value="Submit" />
</form>
<?php echo $retStr?>
</body>
</html>
