Redirect if Recordset Empty while passing URL parameter
Thread began 6/20/2012 11:58 am by Justin@AdventDesign | Last modified 8/19/2012 2:07 pm by Ian S | 2748 views | 5 replies |
Justin@AdventDesign
I'm sure this will be quick for a PHP guy. I want to redirect a page from the update page to the insert page if the results of the query are empty. But, I need to pass the URL parameter along to the redirected page, and can't figure out how to do that.
A typical update page URL would be tbProducts_RelatedUpdate.php?id=PS280
Here's as far as I've gotten:
if ($row_rsLikeItems < 1)
{ header("Location: tbProducts_RelatedInsert.php?id="); }
here ya go:
<?php if ($totalRows_rsLikeItems == 0) {
header("Location: tbProducts_RelatedInsert.php".(isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != ""?"?".htmlentities($_SERVER["QUERY_STRING"], ENT_QUOTES):"")."");
Justin@AdventDesign
It looks like you have an extra curly bracket at the end. Removed and it works great. Thanks a million!
ooops, your right, original post has been updated.
dgifford436261
IF then statement if no records returned by query
I want display a custom message if no records returned:
mysql_select_db($database_dbtpg, $dbtpg);
$query_Recordset1 = "SELECT * FROM products WHERE ProductCategoryID = 'Camark'";
If no records then
custom message
else goto line number or something like this
$query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
$Recordset1 = mysql_query($query_limit_Recordset1, $dbtpg) or die(mysql_error());
Thanks Dan
www.thepotteryguys.com
Ian S
Something like this will do the trick:
if ($totalRows_Recordset1 == 0) {
// Content to be shown with no records in results goes here
} else {
// Content to be shown with some records in results goes here
Cheers
Ian
