Upload Not Working
Thread began 6/20/2012 10:57 am by gpaul | Last modified 6/20/2012 1:00 pm by gpaul | 809 views | 8 replies |
gpaul
Upload Not Working
Using file manipulation, file name is inserted into DB, file is not uploaded to the server. Find attached the helper and the upload files.
I notice when I go through the wizard, when I specifiy a folder (images), the input box shows:
I went through the tutorial and did not solve the problem,
Would appreciate some help.
Gary
helperphp.zip
change the forms encodeing type to multipart/form-data for file upload.
change:
<form  action="attorney_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<form  action="attorney_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
gpaul
Jason
Thank you for your quick reply, I'm sorry but I should have seen that.
However it did not work. It does not list the file names in the DB, it did however upload one file (should have been 2) to the server named .jpg.
Gary
in the upload behavior, you have set the file name to use the Server File Name binding.
this is circular logic.
The Server File Name variable is created once the file is uploaded, and renamed if necessary based on the If File Exists Settings. It is created by the upload behavior, and does not exist until the upload is complete. this binding cannot be used as a setting in the upload behavior.
in the upload behavior, set the File Name the default "[FileName]" instead.
the server file name binding should be used in the insert record behavior, not the upload behavior.
gpaul
Thank you again,
That did not fix it. The file name is not listed in the DB and image file is now uploaded to the server, but as [filename].jpg, [filename]_1.jpg
Gary
sounds like you set the file name to [filename] and not [FileName] php is case sensitive.
also in your initial file, you had been using the Form bindings for the file columns, and not the Server File Name bindings that you should be using.
in the insert record behavior, make sure to use the Server File Name bindings for the file columns.
gpaul
You were correct, I changed to [Filename] Still uploading to server as [Filename].jpg and still not inserting filename into database.
"also in your initial file, you had been using the Form bindings for the file columns, and not the Server File Name bindings that you should be using.
in the insert record behavior, make sure to use the Server File Name bindings for the file columns. "
I'm sorry, I do not know what you mean, could you please specify?
I have uploaded the newer files for you to see.
Gary
helperphp-new.zip
please be aware of case.
you are setting the file name to:
[Filename]
it should be:
[FileName]
Capitol F and Capitol N, you are using lower case for the n.
you need to edit the insert record behavior. for the columns that you wish to store the file names in, Click the lightning bolt icon, and expand the WA Uploaded Files (File Field Name) binding group, (where File Field Name is the name of the file field) and select the Server File Name binding.
gpaul
Jason
Thank you for your patience and help, it is working now.
Gary
