Go TO page on form include
Thread began 6/20/2012 6:21 am by superpac250441 | Last modified 6/20/2012 11:24 am by superpac250441 | 440 views | 4 replies |
superpac250441
I have used framework to include a form on a contact page. The actual form, using formbuilder, is set to go to thankyou.php on clicking the submit. However, what happens is that on submit, it goes to the contact page.
The code in the form:
$GoToPage = "thankyou.php";
Is there something I am missing?
make sure the forms action uses the following code:
 action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != ""?"?".htmlentities($_SERVER["QUERY_STRING"], ENT_QUOTES):""); ?>"
superpac250441
Thanks Jason.
At the moment, the default action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>".
I have to replace it with this as provided by you (thanks):
Is this something that will be fixed in the next update?
it's not actually a bug.
the initial code dynamically sets the forms action to post to the page name.
The code change i supplied sets the forms action dynamically to the page name, but also includes any query string variables.
You dont always need to, or even want to, pass the query string variables used to load the page, in the case of a plugin page, it is needed.
but really, you should only include querystring variables with the forms action on an as needed basis.
superpac250441
Excellent thanks Jason. That solves it for me. I didn't need to do that before for some reason but at least I understand it now as I am using WA framework a lot these days as it makes life simpler when it comes to editing things like forms
