fw not launch, find, memory issue
Thread begun 6/18/2012 4:59 am by software.current355386 | Last modified 6/19/2012 1:13 pm by Jason Byrnes | 2148 views | 3 replies |
rebuid system, upgraded to new supersuite (design extender/ databridge/ ecat5 and bougt themeit as a seperate entity
sequence
installed - ecart5, de 2.0.7, db 2.03
new updates announced (de 2.0.8 db 2.0.4)
installed - theme-it 1.0.2
de-installed - de 2.0.7, db 2.03
installed - de 2.0.8, db 2.04
tried to update an image system not let me gives error message
unable to launch firworks, make sure it exists and enough memory
file exits .. can execute standalone
memory - 12gig installed , have dw, fw runnnning together most of the time.
to makesure - rebooted and tried again, same result.
any ideas
What version of Fire Works? this sounds like an issue with some versions of Fire Works not being able to load from the theme it edit button.
Instead, you will need to open fire works and manually find the image file you wish to update.
using rw cs4 build 10.0.0.495
i have had this working before, that eas ehen had all the individual ssuite modes load seperately not with db or de
i would like to get this workin as it is easier thn routing through fw ... dont always have the source .. still a relaive novice with fw
any other suggeations
