MM_ERROR during Insert Single Record
Thread begun 6/17/2012 5:51 am by paul386190 | Last modified 6/18/2012 8:38 am by Jason Byrnes | 1286 views | 1 replies |
paul386190
Hi there
I seem to be experiencing issues today with the DataAssist Insert Single Record (ISR). I've just updated version 2.0.8 to 2.1.0. When I go into an existing ISR behavior and click on the 'next' button to see the list of columns in the database and the values assigned to each of them the 'Insert Values' inner window is empty apart from MM_ERROR: in the first line of 'Column' and Text in 'Type'. I don't see any of the columns in the database table or the values I'd already assigned to them. I've even tried deleting the server behavior and creating a new one, but it's the same. It seems to be happening on any page I have this applied to - and is the same for any Update Single Record behaviors.
There aren't any problems with the database tables as I can apply a standard Dreamweaver Insert Record behavior and see all of the table columns.
I've tried removing the DataAssist extension, reinstalling it and deleting the MacFileCache file but am still left with the same issue. Done this to both 2.0.8 and 2.1.0 (not installed at the same time though).
Would be very grateful for any advice.
Kind regards
Paul
