Power CMS editor adds <p> tags
Thread began 6/15/2012 9:28 am by Jared Lui | Last modified 6/19/2012 10:35 am by JamieEff | 1533 views | 2 replies |
Jared Lui
I couldn't find anything through a search regarding this so forgive me if this is an old issue.
I have several regions on pages where the editable parts are within styled tags so that only the text is what a client can change (they could further add styles through the CMS editor of course if they want).
What is happening is that there will be a region in the CMS with say exactly this line:
This is content.
In the source code there is only this:
This is content.
And in the database there is only this:
This is content.
Now if I edit this using the CMS to say this:
This is new content.
It appears fine in the CMS view but in the CMS editor source view it shows this:
<p>
This is new content.</p>
And of course I have CSS styles for my <p> tags so this screws up my clients pages every time they edit them and the only way I can fix it is to go into the database and remove the <p> tags CMS is creating.
I have not updated my Extension since Design Extender came out so don't know if this was a resolved issue or just a fluke on my end or something that only I have come across. How can I fix this?
Thanks in advance.
n the admin_cms/contents_insert.php and admin_cms/contents_update.php files, change the following line:
$CKEditor_config = array();
$CKEditor_config["EnterMode"] = "CKEDITOR.ENTER_BR";
JamieEff
you could also edit the developer notes that you use for that particular section from something like this:
include('WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'About', 'Content', false);
to this:
echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'About', 'Content', false));
where <p> and </p> would be reomved in this example. You can also do this for other tags should you wish to remove them
Hope this helps
Jamie
SPT
Never mind
