horizonal sub menu
Thread began 6/14/2012 4:32 am by software.current355386 | Last modified 6/16/2012 9:27 am by software.current355386 | 1890 views | 7 replies |
horizonal sub menu
tried for last 3 days to get horizontal sub menus to work following info in forum i could find, without sucess.
have attached newly crated menu from menuwriter as the file ive been working with have been changed so much with sections commented out whhich may be the problem
f someone who as gt ths to work either update the attached or supply sanple code i would be grateful
WA why does menuwriter givr this option
menutest.zip
you need to convert the sublevel to use 1 LI tag, and have each link in the 1 li, add a width to the sublevel LI tag, and float the links to the left. for example:
<ul class="level-1">
<li><a href="#">Sub Item 1</a></li>
<li><a href="#">Sub Item 2</a></li>
<li><a href="#">Sub Item 3</a></li>
</ul>
<li style="width:315px;"><a href="#" style="float:left;">Sub Item 1</a>
<a href="#" style="float:left;">Sub Item 2</a>
<a href="#" style="float:left;">Sub Item 3</a></li>
</ul>
whe i dothis allmember of submenu act as one
am i somtim wrong
like the submenu behave the same a parent
try this then:
<ul class="level-1" style="width:350px;">
<li><a href="#" style="float:left;">Sub Item 1</a></li>
<li><a href="#" style="float:left;">Sub Item 2</a></li>
<li><a href="#" style="float:left;">Sub Item 3</a></li>
</ul>
</li>
98% there
if you hver overmenu, thenn sb menu ...sub iem1 stayshighlighted alll the time untill you click on menu then i works as it should
send a link please
ALL aapears to work now, what i did notic in menu.css gnerated by menuwrite had two identical sets of coe at end , not sure if copied/repeade when 'my shakes' were active,
ul#cssmw ul.level-1 > li:hover > a, ul#cssmw ul.level-1 > li:hover > a:link {
background-color: #E0AA81;
color: #173232;
font-weight: bold;
text-decoration: none;
outline-style: none;
ul#cssmw ul.level-1 > li.hover > a, ul#cssmw ul.level-1 > li.hover > a:link {
color: #173232;
font-weight: bold;
color: #173232;
font-weight: bold;
color: #173232;
font-weight: bold;
thishad affect , files zipped, attached for evidence
forgot file
menutest.zip
