VERY URGENT error on line 3 php file
Thread begun 6/13/2012 5:21 pm by roxcastaneda251760 | Last modified 6/18/2012 7:53 am by Jason Byrnes | 6993 views | 13 replies |
roxcastaneda251760Beta Tester
I am getting an error here:
contacto-pronet-lactacyd.php
that says:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/lactacyd/public_html/contacto-pronet-lactacyd.php:1) in /home/lactacyd/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/lactacyd/public_html/contacto-pronet-lactacyd.php:1) in /home/lactacyd/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Please help! What am I doing wrong?
Based on the error I'd guess that you have a blank line of code on line 1 of the page: contacto-pronet-lactacyd.php
Php is very particular about not having blank lines of code before starting a session or redirecting.
Nop, no blank line
Please someone from webassist, can't you help me?
Upload a copy of the file referenced in the error and we can look at it.
VERY URGENT error on line php file - files attached
I am attaching all the files.
I should add that this is my version of ContactForm103 translated into spanish, following your instructions from a previous conversation.
See this post for details on troubleshooting the headers already sent error:
showthread.php?t=19285
the error is pointing to line 1:
This usually happens if the file is saved with the Unicode BOM Signature enabled. See the end of the post I linked to for details on checking the BOM Signature.
There is no attachment, please compress the contacto-pronet-lactacyd.php file to a zip archive.
It seemed that the upload went fine, but then it appeared an error. I am trying again, but just in case it doesn't work again, can you send me an email to send the attachements to you, please?
Nop, I've tried with a .rar file, with php file and nothing:
Invalid File
did you read this post:
and check for the BOM setting being enabled?
If you need me to look at the file, compress it to a zip archive (not rar) and send the zip file.
Trying to attach 2 zip files now:
contacto-pronet-lactacyd.zip only has the php file
lactacyd.zip has: WA_Globals and WA_Universal_Email and WA_ValidationToolkit
