Does Powerstore support UK currency (GB£)?
Thread began 8/02/2009 7:37 am by neil186287 | Last modified 8/03/2009 5:09 pm by neil186287 | 2598 views | 6 replies |
neil186287
Looks like a good solution for future sites, and am considering purchasing.
Please could someone tell me if it can configure to display GB Pounds (£) rather than US dollars?
Have asked before, but got no reply.
Thanks.
David StringerBeta Tester
Originally Said By: neil186287
Thanks.
You don't say whether you own eCart or not. I do and can configure it with this extension. I would think that if it can be configured with eCart it can also be done without it!
Jimmy Wu
It looks like you already own eCart, so as David said earlier, you should be able to configure the cart to use GB Pounds using eCart.
neil186287
GBP ok!
Many thanks guys! Am off to purchase Powerstore. I don't have eCart, though. Why should I have it already, Jimmy?
Neil H
neil186287
Variety of templates?
Just before I do - (buy) - I can't find any mention of templates; does webassist supply a few alternative layout/design templates with this solution (i.e. - Header, left column navigation, right column content, footer etc) - or do we need to tweak the css on the supplied front-end design to fit in with the site design? I know that any supplied solution will require tweaking, but it would be good if there were a variety of kicking-off points.
What can I expect?
Jimmy Wu
I apologize, I had checked the wrong user profile to check if you had eCart already. If you have eCart, you will be able to more easily modify the existing PowerStore to use GB Pounds. Otherwise you will have to manually edit several different places to be GB Pounds instead of US Dollars.
As far as the look and feel of the PowerStore, we do not currently have any skins for v2 out, but we are working on them and hope to get them out in the near future. Currently you will need to modify the CSS to match your site layout.
neil186287
Cheers Jimmy, that's good news.
Many thanks.
