Dependent Dropdown
Thread began 6/10/2012 10:07 pm by danielsebas | Last modified 6/11/2012 8:47 am by Jason Byrnes | 687 views | 1 replies |
danielsebas
Dependent Dropdown
Hi, how can achieve a dependent dropdown?
In Data Bridge you only have the option of Creating a Dynamic Array but not the option of populating lists.
In the file attached I want to use both <select> items between recordsets provincias and ciudades. ciudades has the ciuPROID wich is the foreign key for provincias table.
Thank you in advance.
info_insert.php.zip
The Populate list from array behavior is in the Behaviors tab, Not the server behaviors tab.
select the parent select list, then open the behaviors panel (Window -> Behaviors) Click the plus button and select WebAssist -> WA Dynamic DropDowns -> Populate List From Array
