image not shown in powercms edit window
Thread began 6/07/2012 12:33 pm by CraigR | Last modified 6/08/2012 9:49 am by CraigR | 860 views | 2 replies |
CraigRBeta Tester
when adding image content to powercms, the image appears correctly on the live page, but when editing the content area, a placeholder is visible instead, even though the path is correct and the image exists.
if, in powercms edit mode, i right click the image, set image properties, browse the server for the file and update the content, the image is there, even though the path is identical.
(I guess this is because the image wasn't originally uploaded via the powercms interface.)
is there a way to fix this without having to update the image path ?
try deleting all the kfm_ tables from the Power CMS database, then re opening the file manager to recreate them.
CraigRBeta Tester
Ok, I'll try that next time, (I did the manual refresh this time around)
