Quirky repeat region issue
Thread began 6/06/2012 10:41 am by rgolab68503 | Last modified 6/06/2012 2:53 pm by rgolab68503 | 603 views | 2 replies |
rgolab68503
hi there,
I have been building a Order history admin section and have a bit of an issue on the Order_details page. The information seems to transfer over OK from the search page However as soon as i add a repeat region to the the individual items table it knocks out any data below.
1. For example Order_Detail_no_repeat.JPG shows the results with all the data however only one line of the orders.
2. Order_Detail_w_repeat.JPG shows the results with the repeat region showing correctly however all the data below is now not being picked up.
Any ideas?
I have supplied the files with the repear region and one without if that helps give any clues. Any direction on this would be appreciated.
orderreview.zip
the problem is that after looping through the recordset to show the details, the recordset pointer is at the end where there is no data, you need to reset the pointer back to the first record.
after the repeat region code, add the following code to reset the recordset to the first row:
mysql_data_seek
($WADAorders0);
$row_WADAorders mysql_fetch_assoc($WADAorders);
rgolab68503
Quirky repeat
That did it, Thank you.
