Add space to the buttons in CSS Menu
Thread began 6/06/2012 3:53 am by Morgan | Last modified 6/07/2012 10:50 am by Morgan | 1299 views | 5 replies |
Morgan
Hi, I am trying to add some space between the Menu buttons.
|BUTTON 1|<-- 10 margin space --> |BUTTON 2|<-- 10 margin space -->|BUTTON 3|
But can´t get it to work!
I have tryed to put 10 margin right side on Main Menu Item, not working.
I have tryed put margin on every item but with no luck!
Think i´m missing something here :), any ideas?
Regards
Morgan
-- Update --
Found it :P, god talk about being blind!
add 10px right margin to the main level item.
see the attached screen shot.
Morgan
Hi Jason and thank you for the reply, but i could not get the space inserted via the main level item in CSS Menu W, nothing happend when i did.
So i changed it in the CSS-file for now.
Will have a go in a test menu, cos i know i have done it before as you describe it.
Regards
Morgan
Morgan
Looks like it adds the margin to the wrong CSS rule in menu.css when i add it via CSS Menu W.
Will create a test menu see if i get the same problem with that.
-- Uppdate! --
When i add the 10 margin via CSS Menu W it adds in the CSS-file: margin: 0 10 0 0; and that aint working, looks like the "px" are stripped away or sum.
//Morgan
make sure you set the units select list to pixels next to where you enter the number, by default the units select list will be left empty, you need to manually set it to pixels.
Morgan
Hi again and thanks for the headsup, ha ha, you right i totaly missed that!
Thanks a bunch! :)
//Morgan
