session still not destroyed after purchase
Thread begun 6/06/2012 3:10 am by robert254422 | Last modified 6/19/2012 7:21 am by Jason Byrnes | 2716 views | 6 replies |
robert254422
Hello,
My check out succes and failure page have the following code in place below: </html>...
Although this clears the products the orderreference id stays the same if you go shopping after having paid a previous order...
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
@session_regenerate_id();
I have tried (based on examples in this forum) the following also:
1. No @ before session_destroy en regenerate
2. start session after regenerate_is.
But nothing helps the id stays the same on continueing to shop after a purchase has been made (no store user sessions used...)
robert254422
It gets stranger
I have an almost identical version of ecart (except for the layout of the site around it that does destroy the session id and when using that version checkout succes page all works fine up to the point where I start customiszing the page again and add the following: <div id="header_container">
<img src="lay-out/logo-beeld.gif" width="50" height="50" /> <img src="lay-out/2011-logo.gif" width="425" height="30">
</div>
As soon as I put this div in the checkout succes page the sessions stop being destroyed... I have tried this many times and it really stops destroying from the moment I add the above html to the check out success page... This is very weird...
Some help would be appreciated...
wkr
RV
try changing this code:
@session_destroy();
@session_destroy();
@session_start();
I have seen some servers hold onto the ID when they should not be.
robert254422
No success - clarify
Hello Jason ty for your response.
@session_destroy();
Actually works fine as long as I leave out the following piece of html.
</div>
I have changed it to
@session_destroy();
@session_start();
as you suggested.
However this caused the session not to be destroyed with or without mentioned html.
Also I am sometimes getting double shipping. This is not supposed to happen in 1 order.
Say Rule: World 5 KG Max is 25,60 gets shown twice on the confirm page and added twice to the total
Any ideas?
WKR
robert254422
No support ticket
Thank you for your reply. I clicked the link but I dont see a new support ticket in my list???
WKR
RV
should be there now, i have recreated it.
