Can't get mail form to work
Thread began 6/05/2012 12:05 pm by dawn143605 | Last modified 6/07/2012 9:42 am by Jason Byrnes | 1185 views | 9 replies |
dawn143605
I'm trying to develop a php employment application form, where users fill in information and the client receives an email with form fields filled out. I used CSS Form Builder, and although all the fields are there, when I click Submit, the page seems to process, but then nothing happens. I don't receive an email, nor does the sender receive acknowledgment (which is what I want). Also, the page should redirect to a thank-you or error page, but it simply goes back to the form page. I've tried looking up information in the how-to pages to find out what I'm doing wrong, but the problem isn't addressed.
I'm under deadline so really need an answer. I've attached the files in zip format. Thank you for whatever help you can offer. I'm new to php and so need to be walked through this step-by-step.
Thank you.
Dawn Boyer
employmentopp.zip
my first guess is that validation is failing.
to test for this, find the following code at line 50 - 52:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"employmentopp");
and change it to:
    die($WAFV_Errors);
if it is failing validation, submitting the form will show a white screen with a comma separated list of numbers. This will help us determine which validation is failing so we can look into why.
after making this code change, please post a link to your form online where i can test it to.
dawn143605
Thanks, Jason. I did as you requested. The page can be found at employmentopp.php
All best,
Dawn Boyer
iot looks like you may have edited the code incorrectly, that page is showing an error on load. can you send the latest copy of the employmentopp.php page so i can see the code change.
dawn143605
This post has been deleted.
dawn143605
Sure thing. Here it is.
And thanks...
employmentopp_page.zip
yeah, you accidently deleted a closing }
change line 50 - 45;
    die($WAFV_Errors);
    die($WAFV_Errors);
dawn143605
OK, sorry about that. I changed it, but I'm still getting that weird error message when I test. I've attached the revised version.
employmentopp_page2.zip
mmnpinto361034
Can't get email notification working
Got the same problem. I build a format, validate, and espect at the end that the user receives a notification ... but nothing happens.
