Checkbox to add second item to cart
Thread began 6/05/2012 11:48 am by design432499 | Last modified 6/06/2012 3:45 pm by design432499 | 369 views | 2 replies |
design432499
I can't seem to find an example that fits my needs. I have several thousand widgets in my catalog that require 1 of 10 possible battery combinations. Some widgets include batteries and some don't, so I use scripting to work out when/which battery set is needed. Also, I'm using my own catalog database.
I need help making a checkbox in my ATC form that will add the selected battery part by ID to the cart along with the widget and in equal quantities as the widget. i.e. 2 widgets and 2 sets of AA batteries with 1 click.
add your checkbox to the add to cart form, and set the checked value top use the ID number for the battery.
Create a lookup recordset on your page that will query the products catalog and filter the ID column on the checkbox form element.
Go to the server behaviors panel, click the plus button and select eCart -> Add To Cart -> Add to Cart
Set the trigger to Lookup recordset not empty
On the bindings panel, bind each cart column to the corresponding column from the lookup recordset. Bind the quantity column to the quantity form element.
design432499
That worked well.
I had to add checkbox value to the trigger.
Thanks!
