Dreamweaver CS6 Crashes When Clicking the Import Button
I'm using Dreamweaver CS6 on a MacBook Air, when I click on the "import" button in the "Preset Manager", Dreamweaver crashes. It doesn't seem to make a difference what product I am using.
There is a new version of design Extender that should be released a little later today that should correct the error.
once it is released, uninstall the current version of DE from the extension manager and install the newer one.
I just installed Design Extender v1.0.7 and am experiencing erratic behavior from the Preset Manager when I click New. This is also dependent on which pull down menu option I have chosen as it either behaves unexpectedly or simply crashes DW. When I click Import I either receive the attached error or DW crashes.
I installed the latest extensions in the following order:
eCart 5.0.6
Design Extender 1.0.7
Data Bridge 1.0.2
DW CS6 / Mac OSX 10.7.4
was design extender installed last?
The onMouseUp errors is an issue caused by a bug in Dreamweaver CS6, the short story: Adobe removed the onMouseUp function in DW CS6 and we use in quite a lot of places across all our extensions. in the latest eCart and design Extender updates, one of the changes we are making is to stop suing onMouseUp. the migration to completely fix that error wont be complete though till the DataBridge update is released late this week or early next.
No, I installed Data Bridge last. Should I uninstall DE and DB and then reinstall DE last? Thanks for the explanation.
it _may_ work if Design extender is installed last, since design extender includes the update to move away from the onMouseUp function, but if it does, it will only work for Design Extender product Preset groups. The Data Bridge product preset groups will still use the onMouseUp function though.
The update to Data Bridge will correct that problem.
I have installed the update of Design Extender v1.0.7 and while Dreamweaver no longer crashes, nothing happens when I select CSS Sculpture from the drop down list and then click on the Import button, browse to my exported design and then select it, or am I doing something wrong?
send a copy of the export please so I can try to reproduce the issue.
I am able to reproduce the problem. I have logged this as a bug so we can investigate the cause to correct it.
