Blank page after server validation
Thread begun 6/04/2012 9:17 am by pedstone | Last modified 6/05/2012 9:38 am by Jason Byrnes | 3241 views | 7 replies |
pedstone
Hi
After applying server validation to a page with a form the page returned after submiting is blank.
I use DW5.5 and CSS Form builder 2.0.1
Any hints are highly welcome
a blank page means a php error is occurring, but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
pedstone
Thanks Jason
I just did that and got the following error message:
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\W3DC\test1.php:5) in C:\xampp\htdocs\W3DC\webassist\form_validations\wavt_scripts_php.php on line 83
Strangely it worked all before I reinstalled CSS Form Builder 201, FormTK100 and Security Assist 205.
The error just ocures when I use the Validation Show if behaviour
see this thread for tips on troubleshooting the headers already sent error:
showthread.php?t=19285
pedstone
Maybe to add,
I created a form in CSS Form Builder called it in the same page via
require_once($DOCUMENT_ROOT . "registration.php");
and it works - the error I get only if I manualy place a form, add the Server Validation and then add the Show if behaviour
pedstone
Hi Jason
maybe this attached file could show you in more detail what could have gone wrong :-)
pedstone
Hi Jason
thanks again - I found it, thanks to the thread you mentioned above
in the file you attached, there is a blank line at line 1 and at line 9 that will cause the error you are reporting.
