HTML Editor toolbar and IE9
Hi all
Having an issue when testing an Insert page which uses HTML Editor (CSS Form Builder 2.0.1) in IE9. All other browsers and versions of IE appear to work as expected.
The problem is a couple of the tools in the editor's toolbar are not working, namely the insert image, the Image Properties box pops up OK but is pretty much empty of content. The other is the paste text button which just greys out when clicked. Only in IE9.
I checked with another website I built and found it was the same there as well (this client uses Mac so not really an issue).
f12 debugging in IE9 results in a couple of Invalid calling object errors the first being - line 813 on the page fckdialog.html - the code on that line is: var cover = $( 'cover' )
Is my version 2.0.1 of CSS Form Builder (HTML Editor) incompatible with IE9?
I have attached a couple of screen shots.
Any help very much appreciated :)
Regards
Paul Gilbert
