Framework Builder - Theme Bug
Thread begun 6/03/2012 10:57 pm by neo314 | Last modified 6/04/2012 1:53 pm by neo314 | 1026 views | 2 replies |
neo314
Adding an editable region to the template does not add the editable region to the pages based on the theme.
Is this an oversight, or is there a prescribed method for updating the pages based on the theme?
I did see that adding the editable region to the theme page updated the dependent pages. Is there a way to automatically sync that kind of change with the template file?
Updating the theme when the template is updated is not an automated process. You just need to make sure the editable region is added to both the theme and the template.
neo314
I can work with that, but if it is possible to automate it or even create a menu item to "Sync Themes to Templates", I think you should. Some people may be frustrated by that even though adding new editable regions is not a frequent occurrence.
