Problem using DE-CSS Menu Writer 106 on CS6
I am using CS6, Design Extender 106 on MacOSX 10.7.4.
I am encountering problems if I use CSS Menu Writer.
When I try to define the Menu and I click on "+" button and I choose to add a static menu nothing happen (window panel doesn't appear), idem if I choose dynamic menu.
When I try to define a theme, if I click on Define Theme button, the window opens but I cannot go back. The Cancel button doesn't work. It' a loop. I must exit with Alt-Command-Esc.
On the CS5.5 they work.
