radio buttons checked default value
Thread began 5/31/2012 11:44 pm by Christopher West | Last modified 6/01/2012 8:46 am by Jason Byrnes | 2335 views | 1 replies |
Hi Jason, I created a new thread so not to confuse matter, Do you remember that situation of having a list of different shipping addresses for customer and I wanted to use a radio button (in a recordset loop) so that the customer can select which shipping address to use as a default for the checkout page. well with your help, I have managed to get it updating...HOWEVER the problem is as I dont usually use radio buttons, they feel a little frustrating to get them to play nice...What I would like is that when the customer goes on the managed address page they default address that is associated with the customer table would be selected (checked). but I just cannot get this little tweak working....I also tried to put the recordset AFTER the update but then got php error:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in C:\Server\www\dinky\plugins\customer\manage-shippingaddress.php on line 114
could this be due to me being slopping and created 2 recordsets (rsUsers and rsAddress) - should I have just created one recordset for the 2 tables?
anyway..how can I tweak the code so that the address that is suppose to be the default on be selected by default when the customer goes to this page?
Regards
Chris
manage-shippingaddress.zip
1) using 2 recordsets for this is correct.
2) the recordsets should come after the update record code, this is because you are not redirecting to another page.
any time you dont redirect to another page after update, you should have the recordsets after the update
3) The error after moving the recordsets is because you are using the recordset value for the key column value.
instead, create a hidden element in the form, bind the initial value of the hidden element to the rsUsers.UserID column and in the update record wizard, use the hidden element for the key column value.
4) in the radio button, you have the checked attribute set by default:
<input name="radio" type="radio" id="defaultaddress" value="<?php echo $row_rsAddress['AddressBookID']; ?>" checked>
change that to:
<input name="radio" type="radio" id="defaultaddress" value="<?php echo $row_rsAddress['AddressBookID']; ?>" >
5) after you have deleted the static checked attribute, click the dynamic button in the property inspector. Click the lightning bolt icon next to Select value Equal To and select the rsUsers.UserShippingDefault column
