UE in DW templates
Thread begun 5/31/2012 12:19 pm by phill401410 | Last modified 6/01/2012 6:55 am by Jason Byrnes | 1873 views | 3 replies |
phill401410
UE in DW templates
I am trying to set up a simple sign-up form in a Dreamweaver 5.5 Template that emails. DW saved the template with the php extension, LandingPage3.dwt.php . I made a test file, test2.php , and applied the template to it. Does not send. I notice the UE Server Behavior has an explanation point in front of it so I fear I am setting this up to fail from the get-go but I have tried reconstructing UE several times and am stuck. I also pasted in a line of code per this UE wizard warning: You have added or changed code outside the <html> tag. This change will not be copied to documents based on the template unless you insert this tag in the <head> section of your template:
<!--TemplateInfo codeOutsideHTMLIsLocked="true"-->
Also just installed Data Bridge
Thank you for taking a peek. Files attached.
universal Email should not be added to your template.
set up the signup form on another page that is based on the template, and add universal email to that page.
in universal email, make sure to use the submit button pressed trigger.
you can then copy the form on the signup page, and paste that into your template. You will need to edit the forms action to post to the sign up page.
phill401410
UE in DW templates
Jason
I re-made a page, test2.php, based on the template page I would like to add the email to. It sends an email fine. Then I copied the form into the template, LandingPage3.dwt, and that is about as far as I got. Not sure what exactly you mean by, "You will need to edit the forms action to post to the sign up page." It seems to me that if I add Server Behaviors to the form I have to define the page as .php . And DW does not do well applying php templates to pages. This would really be nice to make this work, thank you for your help.
on the template, click one of the text boxes for the form, then go to the tag selector and select the form tag.
In the properties inspector for the form tag, Click the folder icon next to action and select the test2.php page. This way the form on the template will post to the test2.php page and trigger the email to be sent.
