Record in Orders table keeps getting overwritten
Thread begun 5/31/2012 11:37 am by mark284265 | Last modified 5/31/2012 11:42 am by Jason Byrnes | 824 views | 1 replies |
mark284265
I have a page with one static item. When I add it to the cart and successfully check out the Orders and Orderdetails tables get populated correctly. If I go through the whole process again, the data in the Orders and Orderdetails tables get overwritten by the new checkout. The ID of the Orders table is set to auto increment but for some reason it is not.
add the following code to the checkout success page, after the closing </html> tag, to destroy the browsing session:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params session_get_cookie_params();
setcookie(session_name(), ''time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
session_regenerate_id();
