PS4 :: Change the product page layout?
Is there an easy way to change the layout from the standard vertical layout to this?
?post_type=product
With columns and rows instead?
Thanks!
?post_type=product
Thanks!
yes, in the power store admin section, go to the design tab.
in the Additional Options section, you can select to use a grid style catalog.
That's where it was hiding - thank you!
Jason, how do I keep the title from getting cut off on the product name? Please see the attached screen print.
you will need to edit the css for your theme.
in the themes css file, find the following selector:
.content.product .contentBoxGrid h2 {
and remove the white_space:no-wrap; attribute, and add a height.
Jason, one more question. What are the styles that control the top "header" and bottom colors of the grids in the grid format? My client wants everything removed. For example, on the graphic I attached to my previous post, the gray rounded header and footer of the grid box. Thank you.
i think your talking about the background image applied to the following selectors:
#outerWrapper #navWrapper #aboveNavigation {
#footerWrapper {
I actually just found it, Jason. The grid box area - above and below each product image. I just put all the background colors to #FFF and remarked the
/*-moz-border-radius: 6px;*/ /* FF1+ */
/*-webkit-border-radius: 6px;*/ /* Saf3+, Chrome */
/*border-radius: 6px;*/ /* Opera 10.5, IE 9 */
and it seems to be okay now. The client just wanted everything white, without the heavy borders.
Thank you!
ok, glad to hear it is working.
