eCart & Elavon?
I have had 2 potential clients tell me they use Elavon as their merchant and gateway .. does webassist provide custom xml scripts for merchants currently not listed in eCart5? What are the associated costs? ... thanks!
No, you would need to use the Gateway API Documentation as a reference to hand code the checkout through gateways that are not supported.
do you have a resource you can refer who could create the xml & php script for ecart & elavon?
we could help you with this integration through a premiere support appointment. Contact our sales department if you would like to schedule a premiere support appointment.
ok that would be great ... we're not at that point yet - I just needed to know if i needed to use a different cart
