Error using WADB Repeating Table
Thread began 5/29/2012 2:32 pm by neo314 | Last modified 5/31/2012 10:26 am by Jason Byrnes | 886 views | 3 replies |
neo314
When I try to use a repeating table in an existing form, I get this error:
The error appears twice before the bad code is generated.
The code for the location where the table should be placed is below. The checkbox is the only thing high lighted when trying to apply the behavior.
<li class="formItem">
<div class="formGroup">
<div class="lineGroup">
<div class="fullColumnGroup">
<label for="postCategories" class="sublabel" >Categories:</label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup">
<span id="postCategories_Spry"><input type="checkbox" name="postCategories" id="postCategories_<?php echo $row_postCat['id']; ?>" value="<?php echo $row_postCat['id']; ?>" class="formCheckboxField_Standard" tabindex="9">
</span>
</div>
</div>
</div>
</div>
</div>
</div>
</li>
I am unable to reproduce this issue.
can you send a copy of the original page so I can try to reproduce using your page please.
neo314
Can you open a ticket. I don't want to put the page up here.
