Specify specific productID to database driven add to cart button
Thread begun 5/28/2012 9:08 pm by Dennis | Last modified 5/30/2012 5:06 pm by Dennis | 1424 views | 2 replies |
Dennis
Using WADB I am setting up a database driven online store for our club. It will have an assortment of paraphernalia including T/Sweat shirts.
More important at first, is to get a special page of items available for purchase up and running ASAP. On this page I would like to have an individual add to cart button (Including size & color select lists) by each group of items. No search, results, details yet.
Following the Product Options with eCart tutorial, I have set up the first button under T-Shirts. I may have more setup by the time this is read.
My problem: how do I assign a specific ProductID to each of the 5-6 add to cart buttons on this page so I can pull the rest of the info from the database and use rsSize & rsColor.
Note: I believe the recordset’s and database tables are set up correctly because if I temporarily remove the variable from WADAstore_products and set “WHERE ProductID = '1' my size and color lists work.
Thanks,
Dennis
The test page: 2012_National-LogoWear-Test.php.
if you are setting up one add to cart button at a time you are really not using a dynamic add to cart from recordset.doing it this way, you would need to create a products recordset that filters the product table on a specific product ID for each add to cart button, and a separate rsSize and RsColor recordset for each product ID,
normally, you would use a repeat region to loop through the products returned by the recordset and the add to cart behavior would be inside the repeat region.
the way you are doing it is different and requires a separate product, size and color recordset for each product.
Dennis
Thanks Jason.
Dennis
