Error in Databridge
Thread begun 5/27/2012 7:07 pm by sales351414 | Last modified 6/06/2012 8:26 am by Jason Byrnes | 2641 views | 5 replies |
sales351414
Error in Databridge
When Trying to build a data assist page I am getting a java script error.
the log file is below
JS Error:
col has no properties
filename: Macintosh HD:Users:randy:Library:Application Support:Adobe:Dreamweaver CS6:en_US:Configuration:Floaters:WA_SiteTools_ProgressV2.js
lineno: 124
While executing timer in WA_SiteTools_ProgressV2.htm, the following JavaScript error(s) occurred:
Mac computer with CS6 Dreamweaver using databridge and design extender
I have deleted the cache file about a hundred times trying to get this to work
PatriceWebAssist
Mac CS6 is on hold for now. Documented and waiting for fix.
kristina429176
Data Assist error with new Bridge and Extender componets
I have almost the same problem as above but I have not installed my CS6 copy yet I am still in CS5.5 and I am not on a MAc I am a PC. I will attach the PNG snipit I took, but I am getting the same error. I go through the whole set up process and when it is creating the pages it will create the insert page, update page, and results page but it locks up with the error when it is generating table info. I am using an existing table and I have all the fileds linked. Please help as soon as possible with a solutio. i want to upgrade to my CS6 but I did not want any other variables added until this problem was resolved.
what application preset are you using?
Are you having DataBridge create the table or using your own?
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
kristina429176
continuing problem with data assist pages
I am using the preset Dark with some color modifications saved new preset as LR_DDK2. As to the database I am using my own, which I have done in the past, but it also happens if I am creating a new one. I saw another post that says there is a bug where the wa is in lower case on one line and it should be in caps, but the instructions said it was in the Configuration/Shared/WebAssist/DataAssist folder and says to open the file and change the path label from wa to WA (said it was a bug) but it did not mention which file to go into after that folder is open. Is this all I need to do? I have deleted the cache file and retryed it and it stops in the same spot everytime.
for the preset, I was asking about the application preset type, not the design preset type.
this error usually happens if the database columns used by the application preset and the database get out of synch. for example if you where to select to use a Product Administration application type and use your own products table with different column names.
