Problem with adding Dynamic Menu in DataAssist (DataBridge)
Thread began 5/27/2012 3:02 pm by sales351414 | Last modified 5/28/2012 3:48 pm by Patrice | 593 views | 1 replies |
sales351414
I am running CS6 on a Mac. Using Data Bridge to add Data Assist Page(s) Including, Search, Results and Details Page.
When I am editing the field values and making the field type to be a menu type, a new popup comes to Add a Dynamic Menu to one of the pages using Data Assist, The first menu item that I Add works fine, the second one acts as if it is going to be ok, until I select the ok button and then it acts as if it is going to add it and the Configure Dynamic Menu stays up and will not go away, you can select cancel, ok etc.. and it will not go away unless you force dreamweaver to quit. (I am pulling the data for the menu from a My SQL Database.
PatriceWebAssist
Mac CS6 on hold for update. Documented and waiting for fix. Should be soon, I'm guessing.
