Resizer not working with SEO frindly URL's
Thread begun 5/26/2012 8:47 pm by neo314 | Last modified 8/05/2012 12:52 pm by Ian S | 3312 views | 5 replies |
neo314
I am trying to use SEO friendly url's in this program, but I am finding Image Resizer has a problem with that. I'm using mod_rewrite. The rewrite code is not interfering the correct values for PHP_SELF, DOCUMENT_ROOT, etc.
The test url is:
http://mydomain.com/blog/post/this/
post and this are part of the rewrite, so it becomes
blog.php?qs=post/this
The code looks like this:
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1337410240488
ob_start();
<img src="../../images/blogs/<?php echo $row_blogPosts['image']; ?>" alt="<?php echo $row_blogPosts['image_alt']; ?>" width="160" height="120" />
echo(getCachedResizedImageHTML(ob_get_clean(), "../../image_cache", "fit", "#EEEEEE", true));
} // End Cached Resized Image: ImageCacheInstance_1337410240488
I have tried messing around with the second parameter of getCachedResizedImageHTML, but the existing version is correct and the resized images are created as necessary.
The problem is the link url is coming out like this:
src="image_cache/images/blogs/fit/bird_w160_h120/bird_05200200.jpg"
Changing the image reference to:
<img src="/images/blogs/<?php echo $row_blogPosts['image'];  ?>" alt="<?php echo $row_blogPosts['image_alt']; ?>"  width="160" height="120" />
does not seem to help. It should recognize site root relative links.
neo314
I did find where the problem lies. I would suggest that the code detect when the image has a site root relative link (e.g. /image/picture.jpg) and account for that both in the thumbnail creation and in the src code that is put out in the new image.
I can rewrite the code in CachedResize_Image.php to fix it, but your solution may be different and the GUI wouldn't work for me anymore, so for now, I'll use javascript to deal with it.
I suggest either it automatically detects site root relative links, or there is a checkbox in the GUI for forcing a site root relative link. The former would be a better solution as the creation of thumbnails should be possible with a site root relative link as well.
Thanx
Steven
I have forwarded this to our engineering team so they can look into the possibility of adding a Site Relative option.
@Steven, could I ask you what HTACCESS code you are using for SEO friendly URLS? The reason why I ask is that I have gone to many links on googles for the same thing, but the code never seems to work for me when i enter it in a .HTACCESS file. I have even tried uploading the file in either binary AND ASCII but no matter which i select the code i use still dont work. about the only .HTACCESS code that does work for me is some webpage redirection code in a past project.
regards
Chris
neo314
designerwest sent you a friend request so we could pm.
Thanks Jason.
In the meantime, if it helps anyone else, I have implemented javascript with jQuery to work around the issue.
The serverside code remains a relative link so the extension works. The images to modify need to be found by a selector (class, id, images within a specific container, or just all image tags if you are resizing all of them. The code checks the src of each of thos image tags and adds a / at the beginning if it is not already the first character.
$().ready(function() {
// Fix for non-site root relative links with WA Image Resize.
if ($(".postItemPic img").length) {
$(".postItemPic img").each(function() {
if ($(this).attr("src").indexOf("/") != 0) {
$(this).attr("src","/"+$(this).attr("src"));
Ian S
Hi Guys,
Thanks for this thread. It's helped me out a bit this evening in getting the image resizer working on SEO friendly URLs.
I am getting a speed issue though with this fix. I have a list of thumbnails of products in a horizontal looper, and the image resizer is very slow. I have used it on a standard URL before (i.e. products.php rather than /products/) and Image Resizer seems pretty quick so I'm guessing that its the javascript that is slowing things down as each record gets written to the page.
Are there any plans to get Image Resizer working with rewritten URLs anytime soon?
Cheers
Ian
