Google Pro Maps and Design Extender
Thread begun 5/25/2012 11:43 am by kristina429176 | Last modified 5/29/2012 9:02 am by Jason Byrnes | 10997 views | 4 replies |
kristina429176
I am having a problem with google maps displaying the map. I have my SQL database and everything is linking up and it goes throught the whole wizard with no errors, but when I view it live there is nothing there except a white box. I first was putting it into my existing page where I wanted the map and I was ending up with errors affecting the templates on my page so I decided to just work with a new blank php page in dreamweaver so that there would be no conflicts. I only created a div ox for the map to go into and then did the wizard, and it still is not working. The maps program was working before I uninstalled it and installed the design extender program. I currently have the newer versions put in dreamweaver from May 9th. I am currently running CS5.5 and I have my CS6 to upgrade to but I did not want to many variables added until tis problem could be fixed. Please help. THe page address is map_play.php Please let me kow what needs to be done. I need to get this up as soon as possible.
send a copy of your age please and the webassist/google_javascript folder in a zip archive.
looks like there could be a php error.
try adding the following code at liner 1 to turn on error reporting:
error_reporting
(E_ALL);
kristina429176
I have attached the page code and the google javascript folders. Let me know if there is anything else you need. The page I am working with is a blank php page so that there are no conflicts with any of my other code.
kristina429176
I just got the page to load the map, but now the markers are not showing at all.
this is a known issue that will be corrected in the next update to design Extender.
in the mean time, you can fix it by edting the map files in the google/javascript folder.
find all instances or:
'google_javascript/images/
and change it to:
'webassist/google_javascript/images/
