Locked ownership and permissions FTP and edit Theme problem
Thread began 5/25/2012 9:58 am by lr_leal239405 | Last modified 5/25/2012 1:46 pm by lr_leal239405 | 824 views | 2 replies |
lr_leal239405
I've been customizing the Theme (wherever it's not possible through the control panel) directly via the template files, but whenever I have a new theme folder, I have to keep contacting the web hosting co. to unlock the folder. I was told by the hosting co. that it wasn't a permissions problem, but an Ownership problem, so they have to keep changing 'ownership' definition to unlock the themes. However, when they do that, I can no longer save the changed theme via the 'Edit Theme' on the control panel. When I try to save I see a flash of text appear and dissappear on the screen and the theme is not saved. So I have to save it as a different theme name at which point I have to contact the hosting co. again to unlock it if I want to do more modifications to the template or the css or any file I want to FTP on the new theme. Having to go back and forth is a pain. Is there a way around this? Thank you.
lr_leal239405
ok. I responded to the ticket.
