Problem with redirect
Thread began 5/25/2012 8:49 am by Gabriel Tiviroli | Last modified 5/25/2012 10:18 am by Jason Byrnes | 719 views | 1 replies |
Gabriel Tiviroli
I have a problem with the application Data Assist, because although everything works fine, once I insert a new image, or do I update or delete, I get an error page redirect being that everything is correct, clarify the picture is inserted, updated or deleted without any problem, the problem is the redirect. The error that appears is the following:
Not Found
The requested URL /home/laporten/public_html/admin/momentoscompartidos_Results.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request
The point is that the page is positioned correctly and the URL is correct, what could be the problem?
Thanks!
There is a known issue fix for this problem available on the Data Assist download center page.
