homepage loading very slow on first visit
Thread began 5/25/2012 10:23 am by Christopher West | Last modified 5/29/2012 11:56 am by Jason Byrnes | 870 views | 4 replies |
if i cleared my cache or access website on a different computer the homepage takes ages to load (well the main image on the right (which is just static image small filesize etc) but mainly the 12 images (thumbnails) below that take ages to load on a first visit to the homepage) those thumbnails are pulling froma database - if i showed you my code could you possible detect why this is so slow?
Chris
index.zip
Steve
I ran Firebug on the page (your live one) and saw but one small css issue that should not have created the slowdown you are experiencing.
www.dinkyfingerprint.co.uk/
Expected end of value but found 'font-weight'. Error in parsing value for 'letter-spacing'. Declaration dropped.
letter-spacing: 0px font-weight: normal;
template.css (line 61, col 34)
Maybe someone else will be able to determine the reason for the slowdown.
one issue is see is that you are using 4 recordsets to pull the featured images, why not just use one and add an OR condition to the where clause:
WHERE FeatureCategoryType = 'Homepage1' OR FeatureCategoryType = 'Homepage2' OR FeatureCategoryType = 'Homepage3' OR FeatureCategoryType = 'Homepage4'
also in the feature table, try adding an index to the feature.FeatureProductID column and the FeatureCategoryType column, that may help speed up the queries.
Jason, if I create 1 recordset as you suggested how can i code it so that in i can reference records 1 to 3 in one part of the page, 4 to 6 in another part of page, 7 to 9 in another and lastly records 10 to 12 in another area on the page. as the whole idea is to have 4 sections on the page displays highlighted featured products. the method i had used was just a simple recordset loop to showing 3 at a time (hence why i used 4 recordsets to achieve this) as i dont know how to manipulate certain records at a time.
Chris
use the mysql-data-seek() function to change the result pointer location
function.mysql-data-seek.php
to show the first record:
<?php mysql_data_seek($rsFeature0); $row_rsFeature mysql_fetch_assoc($rsFeature); ?>
to show the second:
<?php mysql_data_seek($rsFeature1); $row_rsFeature mysql_fetch_assoc($rsFeature); ?>
and so forth.
