DataAssist Search - retaining search results when using a search results detail page
Thread began 5/22/2012 5:57 pm by sandy170299 | Last modified 5/24/2012 11:14 am by Jason Byrnes | 795 views | 3 replies |
sandy170299
I have a site that I am creating and the DA search feature is working as it should, but when I click on one of the results to go to a detail page, and click the back button, the browsers aren't caching the search results. Is there any way to do this through hidden form fields or something else, instead of browser settings? I'll show you an example:
From this page (index.php), type in cave in the keywords search box.
This will take you to a search results page where you can click on the name of the listing to view the details. All up to this point is working fine.
However, when you use your back button on the browser, or a 'previous page' javascript link, you have to manually refresh the page. I know this has to do with browser caching, but is there any workaround for this? Do you have any suggestions?
Thank you!
I'm not sure i understand the issue.
I have visited your search at:
advSearch.php
typed "cave" in the keywords text box.
I go to the Carvers Cave detail page
When i click the browsers back button I am prompted to Resubmit the form. This is because the action that loaded the results initially was a form submit. If i click yes, it shows the previous results.
the only way to get around the prompt to resend the form, would be to change the forms method to GET instead of using POST.
sandy170299
Unfortunately, changing the action to GET didn't work. I cleared my cache and tried it in different browsers, but the same thing happened - I needed to refresh the page. Is there anything I can do with session variables, or URL parameters that you think might work? Thanks, Jason.
no, this is really just the way browsers work.
