Problem with DataAssist and ServerValiadion
Thread began 5/22/2012 10:09 am by danny405167 | Last modified 5/22/2012 10:57 am by danny405167 | 836 views | 2 replies |
danny405167
I created a recordset to check for duplicate emails for a registration form. I then used DataAssist to add a single record to my database. Then I added a SA Server Validation to my page to check if security code matches CAPTCHA.
The order in the server behavior panels is as follow:
1) SA Server Validation
2) Recordset
3) Insert behavior
I tested the page and it worked fine. I then added $totalRows_rsCheckEmail to my current SA Server Validation to check for duplicate emails. Now the form will not insert the record to my database, even when I try using an email address that is not in my database.
M' I require to have two SA Server Behaviors? One for checking email duplicates and one for checking Security Code.
registration.zip
the code order:
2) Recordset
3) Insert behavior
needs to be:
1) Recordset
2) SA Server Validation
3) Insert behavior
the problem is that you are using the $totalRows_rsCheckEmail variable in the server validation, before it has been created.
with the code in the current order:
1) SA Server Validation - uses $totalRows_rsCheckEmail varaibel
2) Recordset - creates $totalRows_rsCheckEmail varaible
3) Insert behavior
you can see that the $totalRows_rsCheckEmail variable is being used before it is created.
the recordset needs to come first so that the $totalRows_rsCheckEmail variable exists when the Server validation code tries to use it.
danny405167
Thanks for the fast response. Form is working great now.
