eCart- form fields not transferring to cart
Thread began 7/30/2009 9:48 pm by david353947 | Last modified 8/17/2009 8:30 am by Ray Borduin | 1629 views | 3 replies |
david353947
I've setup additional form fields on my product detail page of size, style and color. I've also setup the same as columns in may eCart object. When I create my add to cart button, I select the defualt values and define the "bind to dynamic source" for each however none of those fields show up in my cart when I test it. Any help is appreciated...I'm a newb.
Are you displaying those columns in your cart display? Do you have a place where they should be showing but they are blank, or are you looking for instruction on adding those columns to be displayed on your view cart page (just drag and drop them from the bindings tab).
david353947
Was able to get them working through tech support ticket thanks
Was able to get them working through tech support ticket thanks!
Is there any information you can add that might help others that run into a similar issue?
