Line 12 Javascript error
Thread began 5/21/2012 6:06 am by peterm.bruce341471 | Last modified 5/21/2012 3:18 pm by peterm.bruce341471 | 1633 views | 7 replies |
peterm.bruce341471
Tried the fix to delete the MacFileCache.dat but this file doesn't exist.
I recently upgrade super suite to databridge and deleted all the extensions the manual said to then installed databridge. Now Dreamweaver starts with this error:
The following Javascript error occurred at line 12 ....Layout Manager:shared.js: wa is not defined.
I mailed Webassist direct but had no response.
Image attached.
Ian S
i) Have you installed the latest version of Data Bridge?
ii) Do you have eCart installed? If so, is it the latest version?
iii) Have you tried resetting your Dreamweaver workspace?
Cheers
Ian
As Ian suggested I reckon your worries will go if you cleared the dreamweaver workspace..to me that sounds like you had something of webassist displayed when you closed dreamweaver right before you did the new install upgrade. if you delete the dreamweaver configuration folder (providing you don't have third party plugins installed (otherwise you would need to reinstall those as well). But usually if your doing a reinstall of webassist plugins the best way to make sure you won't get any problems is to delete (or rename the configuration folder) then open extension manager delete any webassist plugins there. Open dreamweaver (this reinitislises the configuration folder. Close dreamweaver then install webassist plugins.
Chris
peterm.bruce341471
New Problem
I've updated all the extensions to the latest version and dreamweaver loads now thanks!
Unfortunately I'm getting a new error:
error in serial check
ReferenceError: WA_addMacPath is not defined
ReferenceError: WA_addMacFolderName is not defined
Nothing is working now...
what extensions do you have installed, including version numbers?
it sounds like you have installed some extensions that are included in the Design Extender or Data Bridge.
see this thread for eXtension install tips:
showthread.php?t=24005
peterm.bruce341471
Installed Extensions
Thanks Jason,
Installed now is:
Paypal ecommerce toolkit recipes
Constant Contact Join My Mailing List
Playstream Video Launch
Paypal ecommerce Toolkit
Payment Buttons For Paypal
Skype Button
Pallet Picker
Design Extender
eCart
Databridge
All latest versions now.
Design Extender or Data Bridge need to be the last extension installed, if you install one of the other extensions after DE or DB it will cause the error you are describing, try uninstalling Data Bridge, then reinstalling it.
peterm.bruce341471
Done!
Thanks Jason,
That seems to have cracked it!
appreciate it.
