Presets CS4/CS6
Thread began 5/19/2012 6:59 am by info4753 | Last modified 5/22/2012 9:56 am by Jason Byrnes | 1024 views | 3 replies |
info4753
Presets CS4/CS6
When I create a preset in CS4 I can't see it in CS6.
you will need to use the preset manager (Webassist -> Preset Manager) in DW CS4 to export the preset, then Use the preset manager in DW CS6 to import it.
info4753
Does that also work the other way around? I have to work run CS4 and CS6 together because WA extensions in CS6 are partly not working on Mac.
yes, you can export presets from cs6 and import them to cs4.
