ready to move the files to root(?)
Not ready but I want to move Powerstore files to root(?) live...
Before I attempt to move, need to know How and Advice before make mistake.
thanks for reading....
it's really not a great idea to move the power store files after you have created the store. Power Store really should be installed to it;s final resting place to begin with.
If you have added any images to the content areas or links, the paths will not longer be valid after you move the files.
if you must move them, it's really just a mater of copying the files from one location to another, then editing the content areas that have images or links in them to fix the paths.
Is there some files that i have changed to see on internet live?
I moved all the files to Public_html but still doesn't show my home page.
Do you want me to reinstalled files because now I be able to working around the Powerstore.
thanks again,
I tried to see my site today.....help please
what is the URL for your site?
from your other incidents, I thought the URL was:
sanpedro.ipower.com/
I must be missing something?
Can you login to ipower and see the problemssssss?
Have username n pw in Support History.
well, if i log into the file manager at ipower for your site select the index page and click the view link, it opens up using the address:
index.php
it doesnt look like you have registered the sanpedrofashion.com domain to connect to your ipower account, you will need to work with ipower on this issue.
I'm little confused that on file that Name server is ns1.ipower.com n ns2.ipower.com.
Sorry to ask you,,, You sure,You think there is a mistake on Sanpedrofahsion.com domain name set up??
thanks for your patient
all i can tell you is that when i login to the ipower file manager, and try to view one of the power store files, it opens up the file using the sanpedro.ipower.com address:
index.php
seams pretty clear to me that if the sanpedrofashion.com domain where pointing to the same file space, it would open the files correctly.
this is something you need to take up with the hosting company, it not something i can help with.
