WA extensions with DWVR CS6 trial?
Thread began 5/17/2012 9:34 am by dan317597 | Last modified 5/18/2012 8:29 am by Jason Byrnes | 715 views | 1 replies |
dan317597
I am considering a 30-day trial of Dreamweaver CS6 and wonder if there are any caveats insofar as my WA extensions (Data Assist and Design Extender suites).
Will I be able to use them with BOTH of my Dreamweaver versions during this trial period (CS5.5 and the CS6 trial)? Will files I create in the trial be usable if I should decided to stick with CS5.5 for the time being? Will any WA custom settings be also valid in DWVR 5.5? (And,if so, how would I export/import any of these custom settings from one DWVR config to the other?)
Many thanks!
- Dan
yes, the extensions can be installed in both version of dreamweaver at the same time.
Yes, you will be able to edit files created by one version of dreamweaver with another version.
any custom presets you create can be exported using the preset manager, then imported to the other DW version using the preset manager under the webassist menu.
