Multiple add to cart on same page
Thread begun 5/16/2012 7:18 am by info321189 | Last modified 5/17/2012 8:00 am by Jason Byrnes | 1093 views | 3 replies |
info321189
Dreamweaver cs 5.5 - wa ecart 5.0.4
Hello, I need to list all products in one page and add at the right the 'add to cart' option without using detail page.
I can see some tutorials ?
on the results page, add the add to cart behavior. On the first screen, set the Properties to Look Up Item from a recordset.
Select the recordset that is used to create the results, and select the ID column
on the bindings tab, leave the ID set as is, for each of the other columns like name and price, click the lightning bolt icon next to value, and select eh corresponding column from the recordset.
info321189
Thankyou very much !!!
you're welcome.
