DataAssist wizzard pages not generating correctly.
Thread began 5/15/2012 1:23 pm by Andrew Read | Last modified 5/15/2012 2:31 pm by msummers194171 | 1810 views | 7 replies |
Andrew Read
I am having some issues with DataAssist wizzard pages being generated completely.
I have previously made the list, insert and update pages for a table, but I wanted to make some changes. I deleted the pages created the first go around, restart the wizzard, choose my preset (which I made previously), make some changes and click finish.
I get "pagename" has been modified outside of dreamweaver, would you like to reload it pop-up box. I choose yes and there is no contend in the <body> for those pages.
Anyone else seen this yet?
msummers194171
Yes, I have seen it happen several times. I usually click NO.
Andrew Read
OK, so it seems to be a bug if it pops up for others... WebAssist?
I have only run into this issue once, and here is how i recreated it:
After running the wizard the pages will be open in Dreamweaver, even if you delete the pages from the files section, they are still open in Dreamweaver memory until you close them.
make sure to close the pages in Dreamweaver before deleting them from the files panel.
Andrew Read
OK, I'll look into that as a possibility, however I believe it happened both times I had the max/min characters issues...
msummers194171
Nope - this is nothing like what I had happen. I was just creating normal DataAssist pages. While the wizard is running, the alert was thrown several times, even for a CSS file. There was never any file deleting happening....
Where any files open in Dreamweaver? It is most likely that a file was open in dreamweaver that was either the same name as a file being created, or referenced one of the Data Assist files.
msummers194171
There were other pages open. But I cannot recall, nor do I have any notes as to what they were. I'll be vigilent in the future, though! :)
