digital file uploads not working
Thread began 5/15/2012 9:17 am by sean366869 | Last modified 5/15/2012 10:02 am by Jason Byrnes | 1900 views | 6 replies |
sean366869
I have been through the support section, made sure all my bases were covered, but still have gotten nowhere with the file upload function. Simple page, 1 form, a file form and 2 buttons. No error messages come up, but the file doesnt upload. The php.ini file is good. Filesize is not a problem, and it is set to accept uploads. The target folder permissions are set to read write and execute, but to no avail.
Here is the page.
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFile("WA_UploadResult1", "upload", "client_upload", "/uploads", "[FileName]", "0", "[FileName]_[Increment]", "24000", "false", "0", "0");
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<title>upload page</title>
</head>
<body>
<form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
<label>
<div align="center">Upload File
<input type="file" name="upload" id="upload" />
&nbsp;&nbsp;&nbsp;&nbsp;</div>
</label>
<p align="center">
<label></label>
<input type="submit" name="submit" id="submit" value="Submit" />
<input type="reset" name="reset" id="reset" value="Reset" />
</p>
</form>
</body>
</html>
Please let me know what i am missing.
Sean
to help troubleshoot:
1) Add the following code at line 1:
error_reporting
(E_ALL);
2) open the bindings panel, expand the WA Uploaded files Global Status group and add the debug info binding to your page.
3) then add the following code just before the </body> tag:
echo("POST:<pre>");
var_dump($_POST);
echo(
"</pre>");
echo(
"FILES:<pre>");
var_dump($_FILES);
echo(
"</pre>");
post back the results after trying to upload a file
sean366869
Obviously have some issues here.
Warning: mkdir() [function.mkdir]: Permission denied in /home/seanmccleery/public_html/Troop-215/WA_DigitalFilePro/HelperPHP.php on line 22
Warning: move_uploaded_file(/1-11-09.pptx) [function.move-uploaded-file]: failed to open stream: Permission denied in /home/seanmccleery/public_html/Troop-215/WA_DigitalFilePro/HelperPHP.php on line 145
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phpcrULXD' to '/1-11-09.pptx' in /home/seanmccleery/public_html/Troop-215/WA_DigitalFilePro/HelperPHP.php on line 145
Upload File
POST:
array(1) {
["submit"]=>
string(6) "Submit"
FILES:
array(1) {
["upload"]=>
array(5) {
["name"]=>
string(12) "1-11-09.pptx"
["type"]=>
string(73) "application/vnd.openxmlformats-officedocument.presentationml.presentation"
["tmp_name"]=>
string(14) "/tmp/phpcrULXD"
["error"]=>
int(0)
["size"]=>
int(110451)
this means that the /uploads folder does not exist, and it does not have the proper permissions to create it.
note that is going to try to create the uploads folder at the root of the site since you are using a site relative path:
uplaods
sean366869
i'm looking at the folder right now. I can change it manually to not be site relative. I'll let you know.
sean366869
fixed
I set the folder in the root, and it works. Now i know what to do if i want to move the folder. Thanks for the help
Sean
you're welcome.
